5 degrees C or F? Also, where did you read the motor temp tolerances?For my motors I use INFRARED thermometer, to check each motor for hotter readings.
Especially in hot weather, all motor temp should be within 5 degrees of each other.
I check just in case one is going BAD, and quits working while in flight.
I check periodically, as I said especially when its hot outside.
I have been wondering the same thing. I believe my fore motors are hotter than the aft after a long flight. I was wondering if that's normal.Do the foward or aft motors run hotter, whats an ok temp range?
Sorry: don.t understand your question. Canada drone has some suggestions as well. I check my motors before and after each flight, especially in extremely hot weather. Each to his own, saved his explanation and put it in my file under motors for further study. Always learning here.5 degrees C or F? Also, where did you read the motor temp tolerances?
