When flying outside or indoors, have you noted your GPS strength when the problem is happening ?
This is mostly what keeps the position stable.
Indoors might even see it come out of GPS mode and into Atti, so be careful and always prepared to actually have to finely control the aircraft.
If you have MAS props, this may be the problem, gains need adjusting (other recent thread on the forum) to prevent instability.
5-10 cm sounds normal and well within specs which say:When taking off and hovering, is the Mavic air supposed to stay still? Mine tends to move around a bit from time to time and even indoors. I would say probably max about 5-10cm of movement but then it corrects itself
Hovering Accuracy Range | Vertical: ±0.1 m (with Vision Positioning) ±0.5 m (with GPS Positioning) Horizontal: ±0.1 m (with Vision Positioning) ±1.5 m (with GPS Positioning) |
