- Joined
- Mar 25, 2019
- Messages
- 24
- Reactions
- 9
Does the rubber feet affect transmission distance being as they are installed on the Quad antenna's
Hi BDOG, sorry pal, my question was not to clear. I meant the push on type that are used to get more ground clearance.No. The rubber feet are at the bottom and the antenna runs the stretch of the arm. Inside it and not all the way to the bottom where the rubber feet are.
Hi BDOG,sorry toNo. The rubber feet are at the bottom and the antenna runs the stretch of the arm. Inside it and not all the way to the bottom where the rubber feet are.
Oh, Well I use 3 D printed leg extensions that slide over the legs (as seen in the picture I am attaching) . I have not noticed any signal degradation. They are not rubber they are 3 D printed PLA plastic.
Plus I use the rear leg extension as a catch handle. It allows me to keep my digits in tact and away from the spinning props.
