I am a long term X large scale RC model aircraft pilot, having owned and enjoyed my MP1 with no real problems for more than 2 years .
But now I have this problem - MP1 RTH wont respond in the normal manner since these last three flights.
I use both Litchi and DJI Go4 Flight Control Apps and the problem appears equally on either of them.
Before this I had no problem with accuracy of Auto Returning to Home with fairly good and consistent landings.
For no reason, these last three flights on separate days and at different locations, RTH failed to trigger normally with the usual long button press.
The RTH started to activate at slow speed for about 5 seconds, the drone then climbed slowly. Kept repeating this sequence of slow forward (toward home point) then climbing each time until the voice finally announced "You have reached maximum altitude 120 meters" then continued to travel very slowly forward (1 -2 Kph). After which I took over and landed the MP manually, to preserve the battery.
I had previously calibrated both IMU and Compasses, with all green lights, and did a repeat calibrations when the problem first appeared.
The only constant is that the weather has remained cool and overcast on each of the 3 events. Trying to remember how many Sats on the screen - maybe 5 - I think!
Seeing this happening on the last three separate landings has me very puzzled and not sure how to fix it, so if anyone can help with any ideas or suggestions,I would be very appreciative.
