My first article for MavicPilots!
itsneedtokno
I'm chillin, appreciate it though.
NSB, FL
Site
codyshoaf.myportfolio.com
Reactions: itsneedtokno
Very good article, very informative and I'm impressed. Did you have help or do it all yourself? Because... Whenever I do such things I always need my wife to fix my horrible grammatical errors.
Thanks!
I wrote it all, using wordpad.. So no spellcheck lol
but in wordPress, yes, spellcheck.
i appreciate it though.
hopefully more to come
Reactions: xunhui
you can use filters to slow shutter speeds, allowing for more color saturation in the end result
There's a lot of misunderstanding about what ND filters do.
They don't give more colour saturation.
They don't change the look of the image at all which is why they are called Neutral Density.
They just cut the light levels that get through to the sensor.
Reactions: LifesShort
Look at PolarPros website.
Then tell them they are wrong.
Not starting anything Meta, but I can cite my sources.
Think about it...
The sky is red from sunset. So you hold the shutter open longer. Allowing for more "red"
  • Haha
Reactions: Ex Coelis
Nicely done Thumbswayup
Think about it...
It doesn't work like that.
Think about it.
If leaving the shutter open for longer lets in more colour (red in your example of a sunset ) then in a normal landscape the blue sky & green grass would be oversaturated if a long shutter speed was used.
Think about it.
I'm only going by what a company that makes ND filters says
Very well done and informative article !!! keep the nice work!!
So PL adds color saturation?
Polarisers affect saturation.
Also, it talks about "2 stops"...
AFAIK, PL filters don't have "stops"
Polarisers don't have stops .. but they reduce the light by about two stops.
Just like an ND8 doesn't have stops , but it still reduces the light getting to the sensor by 3 stops.
Reactions: EdNewbold
What about where it says an ND64/PL (about 5 stops, according to the manufacturer) would further the color saturation?
I know the PL "stops" aren't increasing.... Right?
fiweli
