My turn to lose a mavic pro
jjww
Last night I was testing my mavic. During the flight the drone suddenly lost control and disappeared from LOS, although RC is still connected. With no visual I tried to lower the drone in hope that I could hear or see it. At 20% battery it started RTH. In the end it gets closer, but started auto landing somewhere. I was able to hear the sound during the landing, but no visual.
Here is the flight log: DJI Flight Log Viewer - PhantomHelp.com
I would assume it landed either on a roof or a tree. I could not spot it yet. Help will be much appreciated.
Reactions: Ryan.
Your flight log shows it landed in this tree:
Reactions: rfc and Chirp
Thanks @msinger. That's the tree I had been searching, but no spotting yet. The tree has grown so much, so this picture is super helpful. Maybe I need another drone to do a bird's-eye view :-p
You learned the hard way to set RTH altitude to something higher than the tallest trees in the area you are flying.
Been there done that :)
EDIT: and BTW I went and bought another mavic to find the lost one in the tree canopy. You need a backup anyway, just don't tell the wife.
The Mavic was actually high enough in this case. It auto landed in the tree due to a critically low battery.
Reactions: Odom1957
Do you happen to know why it started drifting away? The log showed yaw error. That's what got me panic in the first place after visual was lost. I was flying a bit high that also made the visual hard.
Were there any magnetic metal objects near the Mavic between the time it was powered on and when it took off? It looks like you powered it on indoors and then carried it outside.
Reactions: Cheech Wizard
I wonder if he put the MP in the car and drove to the launch site after powering it on in the house.
That's correct. I powered it on and then moved outside.
Next time, carry your Mavic to the takeoff location (while powered off) and make sure there are no magnetic metal objects near the Mavic before powering it on. After powering on your Mavic, look at the map in DJI GO and confirm the following:
1) Verify that your Mavic is pointing in the same direction as the aircraft symbol on the map in DJI GO.
2) Verify that the aircraft symbol is not slowly spinning on the map in DJI GO.
Those tips should ensure the Mavic's compass is not being negatively affected by magnetic interference.
Thanks @msinger. That's the tree I had been searching, but no spotting yet. The tree has grown so much, so this picture is super helpful. Maybe I need another drone to do a bird's-eye view :p
Just go ask your neighbor if you can look in his tree, probably some teenagers in the neighborhood would climb the tree for a reward. Looks like a couple houses away.
By the way.. what were you testing?
Already talked to my neighbours and searched for a few times. Could not spot it yet.
Last time I brought my drone to a hiking trip but could not fly because my app was off loaded [emoji26]. So I was testing the newly downloaded DJI go and also how to start the aircraft using remote only.
Mamanov Ramazan
