Need Help barometer location?
djfluent
chicago
Im in search of this **** barometer on this mavic 2 drone for the life of me no one seems to know exactly which board this is on im getting an error saying barometer disconnected restart drone. Ive recalibrated bought a new gps/imu and main board, still with no luck getting her to take flight thanks for the help.
Perhaps this will help. It most likely is on the main board, judging by the picture of a Mavic 2 pro circuit board below. In the badly drawn blue rectangle is what appears to be a barometer. They are almost always encased in a metal can with one or two holes in the cover allowing access to the atmosphere. I cannot identify the component in the photo. Just look for a metal can about 3mm to 5mm in size with a small hole or 2 in it.
Cheers!
Here's another pic:
thank you ill look into that i replaced the main board with supposedly a good one but i may of been screwed :o
That second one is a crystal oscillator, no hole, just a printed dot. First one is baro sensor though.
You are correct! Should have looked closer.
Cheers!
Alguien logró verificar dónde está el barómetro? Ando buscándolo en la placa madre y no lo encontré, y la última foto publicada aquí con el chip destapado no es un barómetro o si? Yo sé que los barómetros son esa tapa metálica con 2 agujeros de tamaño de 3mm o 5mm
zotacreborn
