Do I need an sd card reader to transfer the video to my computer? Or can I Use the transfer cable that comes with the mavic air?
no need to remove SD card, the cable can be used to transfer data onto laptop / pc whichever you useDo I need an sd card reader to transfer the video to my computer? Or can I Use the transfer cable that comes with the mavic air?
So the cable can also be used to transfer from the sd card?no need to remove SD card, the cable can be used to transfer data onto laptop / pc whichever you use
yes, guess the cable is mostly for this purposeSo the cable can also be used to transfer from the sd card?
You can ... but it's awkward and a lot slower than popping the SD card, putting it in a $3 adapter and using that to copy to your computer.So the cable can also be used to transfer from the sd card?
With my card reader I can DL an entire 64GB card in less than 10 min.You can ... but it's awkward and a lot slower than popping teh SD card, putting it in a $3 adapter and using that to copy to your computer.
Agreed! It's a ton easier with this Micro SD card removal tool (or your tweezers of choice):I find it a complete PITA to remove the SD card
Agreed.... got a couple!Agreed! It's a ton easier with this Micro SD card removal tool (or your tweezers of choice):
