New at this.
JOHNMN
Roseville, MN 55113
Just acquired a Mavic 2 pro, no experience, but it looks like the batteries must be charged routinely to keep it functioning. There is some talk about having a chip so I don't get involved with airplanes or helicopters. So, as soon as the snow disappears, I want to try this out and see where I can fly it. Seems to be a lot of places to avoid.
Hello from the Crossroads of America JOHNMN
You can download the manual here.
The Mavic 2 isn't RID compliant and will require a module when they become available closer to the September 2023 due date.
You should register the aircraft with the FAA.
And you should take the TRUST test and keep a copy with you when you fly.
Good luck and welcome to the Forum. :cool:
Welcome, read the manual SEVERAL times and ask questions concerning anything you even SUSPECT you do not fully understand.
Remember low, slow and close in wide open spaces, preferably over grass etc. rather than a hard surface, are your best bet whilst learning, leave high and fast to the young bucks.
Low and close, I would also suggest you turn obstacle avoidance off. Since you have no experience it's an added complication that may confuse you.
Welcome from the dirty south in Savannah, GA!
Do a TON of research around here about the operation of your drone, the care the batteries need, and FAA laws that are required. Go right now and get your "trust" certification. Thats Step One.
Welcome to the forum, from Hauptmann in North Texas!
I fly a Mavic 2 Pro also--great machine. I envy you for all the scenery in NY! I'd love to fly there some day. Been there many times, but not since getting "drone fever".
Do yourself a favor: Follow Yorkshire_Pud's advice and study that manual! If you ever have questions, just ask. We have over 150,000 members worldwide who enjoy helping fellow droners learn and grow as pilots and photographers.
Glad to have you with us!
Rich R (aka Hauptmann)
As a New Drone Pilot, there are a couple of Legal Things you may need to do… And you have already been given the heads up so I will only say, do it.. If you do have the opportunity to be visited by the authorities, they are getting smarter and asking for your "credentials…"
Since you live in Minnesota, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro/Zoom, including the User Manual.
Fly On and Fly Safe…
Acabo de adquirir un Mavic 2 pro, sin experiencia, pero parece que las baterías deben cargarse de forma rutinaria para que sigan funcionando. Se habla de tener un chip para no involucrarme con aviones o helicópteros. Entonces, tan pronto como desaparezca la nieve, quiero probar esto y ver dónde puedo volarlo. Parece ser un monton de lugares para evitar.
Acabo de adquirir un Mavic 2 pro, sin experiencia, pero parece que las baterías deben cargarse de forma rutinaria para que siga funcionando. Se habla de tener un chip para no involucrarme con aviones o helicópteros. Entonces, tan pronto como desaparezca la nieve, quiero probar esto y ver dónde puedo volarlo. Parece ser un montón de lugares para evitar.
Hi , I'm fond of droning with medium experience. I have a MAVIC air 2. I suggest you to review the manual of the dron in the battery section. There you will find a lot of information about the batteries. I would suggest not to work with the batteries until they reach 0%. The recommended level is 20%. Don't charge the batteries when they are still hot. Good use of the batteries make them last more.
dojin23
