New drone owner from FL
Welcome to the forum from Oz. I use Sandisk extreme 128gb in all of my drones from the mm to the PPV2. Had no issues with these cards. Lot cheaper to buy in the US than Oz, hope you enjoy your time with the forum.
Regards
Thank you for the feedback. Would you recommend having more than 1 card incase of any situation?
Mate I have plenty of cards from 16 to 128gb, for different jobs and cameras. To be honest I have only had one issue with a card from my carcam that wouldn’t clear the files. Other than that I’ve had no trouble, but I am a great believer in having backup systems.
Regards
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Welcome to the forum! :)
Im new to this page and a just brought my first drone ever. I can't wait for my mavic air 2 to arrive.
Here are some things to help you get started with your Mavic Air 2:
  • The current Mavic Air 2 manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Air 2 downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Air 2 manual.
  • This video covers all the basics of the Mavic Air 2.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
whats the recommended memory card size I should buy
Check out this article:
Best memory card for your DJI drone
Hi Roloman1012 Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Air 2 manual HERE
You want an SD card that is U3 for 4K
Most of all have FUN
sscott062
