New Guy (admin edited) in PA
Just took flight for the first time in Lancaster Pa with my mini 2! holy smokes i love it! Looking forward to exploring the forum! Any one else local to Amish country?
Welcome from the Hampton Roads area of Virginia. I too am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). Open the front legs, open the back legs of your drone, then remove the Gimbal Cover.
Place the drone down while it finishes its self-test (collecting satellites, etc…).
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby;" also read over the user's manual… the link is below in case you did not get one…
Happy Droning
Welcome to the forum
Happy Droning
Thank you! I’m also looking for a pelican case to provide better transportation storage safety. Any recommendations?
Hello from the Crossroads of America jjcrt2.
I purchased a Nanuk case for my Spark years ago and liked it.
NANUK Drone Cases | Official NANUK Protective Drone Case Online Store - Waterproof & Indestructible Hard Case
I also purchased a SYMIK case for my Mavic Air 2 and like it as well.
Here's one for the Mini 2.
https://www.amazon.com/SYMIK-A310-MM2DL-Waterproof-Controller-Protection/dp/B08QFQDXT3?th=1
Many others to choose from on the web.
Have fun shopping and welcome to the Forum. 😎
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
jhgfdhjrye
