New guy from Wilmington, NC
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
New to the forum and to drones, just picked up an Air 2s and have a few short flights on it. Looking forward to learning more on these forums
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice even though you are flying a different Drone.
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby."
Happy Droning
Greetings from Birmingham Alabama, welcome to the forum!​
Happy Droning
To tack onto what I've already said...
Below is the link to all of the downloads offered by DJI for the Air 2S. You will also find the 57-page Air 2S User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Air 2S - Download Center - DJI
lab916
