New guy with a question
Holokai Mike
Hey everyone, I am new here.... my involvement with a drone is centered on fishing. And now Raymarine has a MDF that can actually control the drone from the touchscreen aboard your vessel. It is really cool for many reasons, especially it ties the home feature to the moving deck of your vessel. Almost lost it the first time, ha.
My question is can the DJI Mavic track the boat directly below while scanning the surface area in front of you, scanning for foamers off in the distance? I know I can track with the camera looking at the car/boat/person it is locked onto filming; but I need the camera looking forward. Can the down sensor track the boat is my question?
Welcome to the Forum.
Yes the drones sensors wil work while tracking the boat however , although the processing on the sensors have gotten much better on the newer drones, they miight be a bit to slow to navigate waves or foamers. I would consider getting the Resuce Jacket we make for Boaters to give you an edge over the water with your drone.
The Rescue Jacket will provide you with the ablity to hand catch safely and land on the water and increase your visual line of sight while flying from a boat up to 3000 ft.
Phantomrain.org
Gear to fly in the Rain, Rescue Jackets to land your drone on the Water.
...now Raymarine has a MDF that can actually control the drone from the touchscreen aboard your vessel...
My question is can the DJI Mavic track the boat directly below while scanning the surface area in front of you... Can the down sensor track the boat is my question?
Hi there & welcome to the forum 👋 :D
Much of DJI's drone functionality (like tracking/following) comes from the control app... don't know anything about Raymarine's software, but if you doesn't find any support regarding the function you want there, you're out of luck... at least when it comes to using Raymarine as the means of controlling the drone.
Natively (with either the DJI GO4 app for the older drone models, or the DJI Fly app for the newer models) the Mavic series doesn't support a tracking solution that you describe, it can track objects, but does that with the main camera & no, the bottom visual positioning sensors can't track anything from height besides measuring height above what's directly under the drone if within the sensor reach.
If you have a Mavic model that supports the Litchi app + the companion app Litchi Magic Leash, you could achieve what you want... the drone will GPS wise follow either the controller (or a paired 2:nd mobile phone) from a chosen distance & side of the object (while the drone is turned towards the followed device)... & you can manually maneuver the gimbal tilt.
So with this you could position the drone to follow the boat from the rear turned towards the boat... & you can rise the camera gimbal up manually to look further ahead.
Here a link where they describe the Litchi Follow function --> Help - Litchi
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Mavic Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Landlocked in my area. Must be some oceanic term. Help please!
I think the scanning for foamers is referring to other watercraft that might be kicking up a wake that could be visible enough to track with the drone or maybe confuse the tracking software…
Other uses of the word "foamers" is referring to people who are so excited they are foaming at the mouth… To me, that sounds a lot like most Drone pilots…
  • Haha
Reactions: Phantomrain.org
DAVID0344
