New here
I am not sure but I think you are planning to buy the Mavic 3 and that you are new to Drones, so in that case, since you live in the Netheralands, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Happy Droning…
Thank you for these instructions. I will save in the main drone-folder on my pc.👍
Reactions: LoudThunder
edypilot
