I think to buy an
Mavic 3 and learn to fly drone,
mavicpilots.com
I am not sure but I think you are planning to buy the
Mavic 3 and that you are new to Drones, so in that case, since you live in the Netheralands, there are specific laws and rules for you to follow, please check to ensure these are current.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic 3, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mavic 3
www.dji.com
Happy Droning…
