New here
Stephen Otto
New Zealand
Hi. My name is Steve Otto, from New Zealand. I was a member a few years back.
I still have my Mavic Pro from 2016, and still fly it but not for about 8 months. Been to Hawaii and Alaska 2017.
So yes, I have a question. For some strange reason my SD Card is not recognised. All 5 Cards the same.
I have updated everything I think. Any ideas on how to fix this?
Hello from the Crossroads of America Stephen Otto.
Try reformatting the cards in a PC and/or the aircraft and see if that helps. 🤔
Welcome to the Forum. :cool:
Thankyou for that quick reply. I have copied everything on all 5 Cards to my PC and Formatted them. They are all now empty. I guess formating the aircraft is by cable to my PC, then a new software/firmware installation? I was not keen to do this, but it makes sense. Anything that should be done on the Remote?
Thanks, Steve
Have you tried this?
Welcome back, you've posted your question in the Pilot Check In Forum, if you do not get an answer, you might want to post it in the General Discussion or the Mavic Pro Sub-Forums. The members most knowledgeable about your issues may not be monitoring the newcomer's forum.
Good Luck and welcome back!
Welcome to the forum.
Liger210
