New member and new drone pilot
Welcome to the forum! :)
Welcome to the group. Enjoy and have many safe enjoyable fights.
If I may. Trained dogs for many years. Don't know if your chasing yours or someone else's dogs, however, chasing a dog with a drone can cause significant behavioral problems. Research has shown drones can cause stress, anxiety, and fear in dogs, even in breeds with strong prey drives. Proper introduction and desensitization can avoid these problems. Gradually introduce them to drones, starting with the drone being stationary and far away, and slowly decreasing the distance and increasing the drone's movement over time. Reward their calm behavior with treats. Ensuring the dog is comfortable and relaxed are also important.
Not trying to be drone police, but simply showing a concern for the dogs.
i am a new drone pilot, i fly DJI Mini 2
Since you live in Serbis, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
LV_NV_limitless
