New member, Central CT Intro...
Wunderkat
Vernon, CT
Brand new pilot. I appreciate finding this forum, and the add!
I retired from a long tech career and I've been an amateur photographer since my kids' soccer days in the '10's.
My first drone was a Mini 3 Pro in '24, but for various reason including a flyaway, I don't have a lot of hours yet. I have the time to pursue more flight hours this year, and eventually I'd like to be licensed and work commercially or creatively on small scale.
My first responsibility is to respect and learn from experienced pilots like the ones who hang out here, and that's what I plan to do.
Thanks again for the add!
John G
Welcome to the forum From Bakersfield This is a great place to talk Drones!
You wrote that your "first drone was a Mini 3 Pro in '24" And you write that like it was so long ago… By my calendar, that was literally just two-weeks ago… L o L . . .
Your other posting about batteries is beyond most of us since you did not state where you acquired you non-OEM batteries or if they ever worked with your drone or if there is a reason why you are not using the original OEM battery.
As a relatively New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Connecticut, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum @Wunderkat! :)
After flying many DJI consumer drones since 2016 (I own most all of them), here's what I recommend you do (at the minimum) to get started with your DJI drone:
  • Skip buying a non-DJI practice drone and start with any of the DJI consumer drones (ideally the model you'll be flying most). While it's true DJI makes one of the most expensive consumer drones, you likely won't learn much about your DJI drones by flying drones made by other manufacturers. And then you'll be back to square one again when you finally decide to ditch the practice drone and start flying a DJI drone.
  • Before attempting to fly, watch some videos on YouTube.com to learn more about your drone. Search for something like "Mini 2 Beginner's Guide" (replace "Mini 2" with your drone model).
  • Read the DJI manual (available in the "Products" section of the DJI Download Center) from beginning to end (maybe a few times). You're certainly not going to remember everything, but it'll give you a good understanding of the available features and capabilities of your drone. And then you can go back to the manual or YouTube videos when you need to take a deeper dive into a specific topic.
  • Before flying in the US, you must register your drone with the FAA (if it weighs 250 grams or more) and take the free online TRUST test (I like this one).
  • When flying in the US, your drone must broadcast RID if it weighs 250 grams or more (or is registered with the FAA). Many DJI drones (especially the newer models) have that feature built into them. If you're ever flying a drone that does not broadcast RID (meaning it's not on this list), then you'll need to attach an external RID module like the Holy Stone or Ruko RID module.
  • Don't power on your drone or take off when within about 10 feet of any magnetic metal objects (like your car or rebar in concrete sidewalks). See more on compass interference in this compass calibration guide. Before takeoff, always confirm that the aircraft shown on the map in DJI Fly (or the app you're using) is oriented in the correct direction. Any discrepancy is usually a sign of magnetic interference in the surrounding environment.
  • Before taking off, always review the drone settings in DJI Fly (or the app you're using) to ensure everything is set as expected. If you do plan on flying near any obstacles, ensure the RTH altitude is set properly in case your drone needs to automatically return back to the home point mid-flight.
  • Never take off before DJI Fly (or the app you're using to fly) audibly mentions or shows the home point has been set. The drone will attempt to fly back to the home point location automatically if it loses connection with the remote controller, so it's crucial to ensure that location has been set prior to takeoff.
  • DJI drones have a lot of awesome automated flight features. Use them with caution and never assume they are always going to function as expected (always be ready to take control if needed).
  • Sensors are great and they can help prevent your drone from crashing into obstacles. They are not foolproof though. Never rely on them 100% or assume they are going to work perfectly in all flight conditions -- or react the same way when flying in similar conditions from past flights.
  • Find a flat, wide open place to practice (free of people, trees, and all other obstacles). It's pretty hard to crash a DJI drone into the ground, so you'll likely have the best success if that's your only obstacle. Continue flying in this location (or similar locations) until you're able to control your drone without thinking about it (like riding a bike).
  • Make sure you can easily see your drone at all times (required by law in most countries). After removing all nearby obstacles, nearly everyone who crashes/loses a drone is either not watching it with their eyes or cannot clearly see where it's located.
  • The screen is chock-full of great information. Use it as a reference (sparingly) as you do when looking at your dashboard while driving a car. It's also a great tool for framing the perfect photo or getting your drone in just the right spot before hitting record. If you're mostly staring at the screen while flying, you'll probably have no idea where your drone is located.
  • Don't fly in sport mode until you're comfortable controlling your drone. You don't want to get into a situation where you need to maneuver quickly and aren't quite sure which stick to move (another reason not to practice near obstacles).
  • DJI batteries require special care that is unlike other batteries you commonly use. To prevent any damage to your DJI batteries, follow the tips in this DJI battery maintenance & storage guide.
  • DJI drones record a lot of useful information in the TXT flights. The logs are helpful for things like troubleshooting issues you experienced during a flight, locating a lost drone, and many other things. The TXT files can be found on your phone/tablet or remote controller (if it has a screen). See these instructions for more details. And then you'll need a tool like my free online DJI log viewer or Flight Reader (keeps your flight logs offline) to decrypt and access/view the data within.
This is great advice and lots of resources I hadn't found yet. Thanks. I'd like to start a separate thread about the battery issue, which was indeed about requiring an OEM battery to active my Mini 3, and DJI wouldn't simply tell me that.
Again, thanks for all the tips!
Reactions: Hauptmann
Here is a link your other posting...
The issue you have is that DJI OEM Batteries are "Smart Batteries" and are wired up so that the condition of the battery is sent to the Firmware… This information includes: Temperature, Voltage, Number of Charges, etc… Below is the information that shows up on my controller's Menus (Safety, Battery Information…) as reported by the Drone…
Then the Fly App Software takes this Telemetry from the Drone and computes the Batteries' specifications… In this display, in the RED Oval, are the Percentage of battery power left (91%), Predicted Flight Time ( 25-minuutes, 35-seconds), Signal Strength (5-Bars), and the Number of Satellites (12)…
And if the required information is not provided and your Non-OEM batteries may not provide this information to the Drone and therefore, the Drone will not work…
Again, have you tried an OEM battery?
Very valuable advice. I really appreciate it, msinger.
Thunder,
I understand and I'm pretty amazed by all the data that can be gathered by any, consumer drone.
My flyaway data, which I shared with DJI support, was fascinating and damning at the same time, lol.
Real quick answer to your question, though is: YES!
I now have proven, with absolutely zero help from DJI support:
---A proprietary, DJI battery is REQUIRED to activate a brand new '24 Mini 3.
--Once activated using their proprietary battery, aftermarket batteries work just as expected.
So I ask, as a new pilot, how TF was I supposed to already know that?
I am 100% turned off of DJI as a result of this. Especially after they offered me a "brand new SD card"(!!!) for my trouble.
Perhaps you can escalate this topic if you think other pilots could benefit from it.
Thanks,
John
So, the question is was your mini 3 Pro a new or a used drone? All New DJI Drones come with an OEM battery.
Since you have a non-OEM battery, that drone was probably a used one; or if it was a new one and you also bought non-OEM batteries for extra flying time I would also ask why would you not use the new OEM Battery in the first place?
Then, if it was a used drone and it only came with non-OEM batteries, did you know they were non-OEM batteries and if you did know, did you communicate that to DJI Support when you called them?
Unlike an automobile, a DJI Drone's battery is an integral part of the flight systems. But you take your car while it is still under warranty and you change the spark plugs and then take it in for service because it misses, there is a good chance the service department will install OEM spark plugs to ensure your aftermarket items are not deficient…
Well, as you know, the Non-OEM batteries are deficient as they will not "do what is necessary" to activate a drone…
Yes, this is an issue that is not well known. I would recommend you post a new thread under general Discussions with the Title, "Warning, DJI Drones will only Activate with an OEM Battery." And then wrote out a narrative with a bit more detail. Like what does work and what does not work (see blow…).
I am curious, does that non-OEM battery report the specifics as I pointed out earlier: like Remaining Flight Time and Battery Strength in the fly App. Does the Menu show the actual Voltage, Battery Temperature, and Number Of Times it has been Charged?
Inquiring Mind Want to Know…
John G
Welcome to the forum, you'll find a most helpful community here. HFTA
PNW_Aerials
