New Member from East Central Tennessee
GregoryUnltd
Tennessee
Hi everyone,
I am a new member from the Cumberland Plateau in Tennessee, really close to Big South National Park and Pall Mall, Tennessee (the home of Sergeant Alvin C. York). I just purchased an Air 3 and This is my second drone,(my first was a Phantom 4) but it has been like 6 years since I have flown. I was in the Automobile business and used my first drone to market myself and the dealership I worked for. That being said, I never had the time before to really get involved in this hobby too deep and I am really looking forward to finding as many uses for this little drone as I can. I hope to get some good footage of the scenery around my area and welcome any advice any of you have.
Thanks for letting me join,
Greg
Understand this, things have changed in the 6-years, if you use your drone tomarket yourdelf, you MUST get a Part 107 License now… It is no longer a Free For All…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Tennessee, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome to the forum! :)
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you may have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response. Fly safe and stay safe!
Thank you so much! I'll get on getting registered asap. I was kinda wondering about that. I'm VERY rural but I still want to be legal. Can't afford fines after spending for this drone, lol. Again thanks so much for the teaser trove of info!
Greg
Greg,
Sometimes the Rural Setting is the most contentious and the most invasive… Probably most of your neighbors appreciate their privacy and if you fly over their property, many folks consider that trespassing…
And if they do not like it, they might call the authorities and claim all sort of outrageous charges, you are scaring the animals you are peeping in their windows, etc..
And a lot more drones get shot down in a rural setting since more shotguns are available out there…
Let them know what you are doing and even though you cannot legally do roof/barn/building aerial inspections, you will not find any "FAA Revenuers" hiding in the bushes… so whose checking…
Fly Safe, Fly Legal, Have Fun…
LoudThunder
Greg,
LoudThunder
yes I agree, and thanks again.
Welcome from Wisconsin!
Thank You!
Hello again,
Well I went to the FAA and got my drone registered today and took the TRUST test. I also went ahead and paid an additional $5 to register it for commercial too. I was curious about the cost of the Part 107. I see a bunch of courses etc. But what is the actual cost of taking the test not including the study courses.
Thanks again for your help!
Reactions: LoudThunder
Hi everyone,
Greg
Welcome from central England.
plamenkamenov
