Rfamily
Wisconsin
New member from Wisconsin
Looking for some guidance as I want to purchase a drone that I can use when fishing on Lake Michigan to take pictures and videos of seniors and others out with me catching salmon. Which Drone do I consider being none of the DJI are waterproof and need to have the drone that will have auto tracking and return home capability to the controller reference point which is nonconstant and constantly moving? Thoughts and suggestions would be appreciated.
You will get a lot of wonderful advice, and you only have to decide exactly what you want to do and how much you are willing to spend to do it… YouTube is your friend, when considering a particular drone, watch lots of videos, you will soon be able to separate the truth from the hype…
Also as a Soon to be New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. Once you decide on a drone, if it weighs more than 250 grams you will need to register it ($5.00), no biggie, but an FAA rule…
You can get the TRUST Certificate at the Pilot Institute Web Site (FREE…).
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Wisconsin, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
........ and need to have the drone that will have auto tracking and return home capability to the controller reference point which is nonconstant and constantly moving? Thoughts and suggestions would be appreciated.
Welcome.
If I understand you correctly the latter is known as a dynamic home point and I know of no DJI drone that offers it 'out of the box' whilst using the relevant DJI app.
HOWEVER
1) those DJI drone's that can use Litchi as a control app can, I think, set up "dynamic home point" whilst flying via Litchi.
I HAVE NOT used the feature myself and it is a vague recollection of seeing it offered whilst going through the Litchi menus.
You'd need to check with Litchi etc. to see the relevant models.
2) You can reset the home point manually in the DJI's control apps but you would have to remember to keep updating it every few minutes or so.
Welcome.
HOWEVER
For a dynamic homepoint this is probably the best way really. As for WATERPROOF-No drone can be completely waterproof BUT you can cut down a majority of the moisture by putting on a wet-suit from Phantomrain.org Any of the DJI drones would serve you well. If you are not planning on buying Brand New then may I suggest an AIR2s, They are very cheap as far as batteries go and IMO they are one of the best drones DJI made. but really you couldn't go wrong with any of the models. With all the stuff you already have to take to the water with you, you might consider a MINI and
Welcome to the forum from Bakersfield!
I fly over water a lot and it really takes never of steel (harder than City night flying) and a lot of studying especially from a moving boat. I would say get a lot of experience just flying a drone and dealing with the the unexpected then try it. Once you have a couple of months under your belt you will love this hobby.
Welcome to the forum! :)
Appreciate everyone's kindness with your response, thoughts, and experience with the art of using a Drone. Wondering if it would work to use the function "Return to Controller" and set the current return reference point just before you send the Drone to return to the dynamic location versus "Return to Home"? As it returns could you cancel this action just before it lands or at a specific height to stop it and simply grab it by hand? Another question if you do a video of someone let's say in a panoramic view and want to get the individual's verbal comments how would you do the audio recording so is in sync with the video recording?
  • Wow
Reactions: LoudThunder
You can always update the Home Point with a GPS enabled device during the flight.
Might have to do this a few times if on the move so the aircraft doesn't go to the original HP when a low battery / distance warning pops up.
Practice hand launch / landings on land first. It can be tricky from a boat that's rocking and drifting in circles if stopped.
A neck lanyard attached to the remote will help.
Fly backwards when landing as the sticks are orientated to muscle memory.
If all else fails, take extra props and catch it with a hand fishing net. The gimbal might get damaged, but that's what DJI's Care Refresh is for.
To record audio during a flight for narration purposes, you might try using a screen recorder for the device you're using or use a separate recorder and sync it together in post. 🎬
The "return to contoller " thing in DJI control apps applies changes the home point to where the controller was at the time the change was applied. In a boat it would be very quickly out of date and you need to reset it at intervals. IT IS NOT "dynamic home point".
You can cancel an RTH at any point in time, place and height. READ the manual for your chosen drone carefully as some drones cancel an on going RTH if you make certain joystick movements.
In addition to MA2 317's comments about hand catching practice, I would suggest you read the entire RTH section of the manual several times then go out somewhere safe and work through ALL the RTH behaviours in practice before you encounter them in real life. In real life you will probably be panicing and not thinking clearly, previous experience may reduce the level of panic and muddled thinking.
A lot of useful advice from the best flyers around. I’d say practice practice, practice over land before you take off over water. I have done a few hundred flights with my Spark and MA2 and have only flown over water I think 4/5 times-it does nothing for the heart! Good luck and welcome to our Forum.
Reactions: MA2 317
The more I read and think about what the OP has asked I think the OP wants an Autonomous Operated Drone capable of accepting Voice Commands… He just has to wait a few years to the Drone AI market to catch up… L :D L . . .
Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!
Reactions: wjkrysak
Reactions: MA2 317
Ray in Kingwood
