New Mini 3 Pro owner in Montana
madkiwi
Florence MT
Just unboxed and had my first flights today of a Mini 3 Pro. Got the deal from Costco with 2 extra regular batteries, keeping it under that magical 250g weight at all times.
So I just did a little flying around my back yard, snapped some pictures and got the hang of things. No crashes yet (5 little flights) but annoyed the crows nesting across the street. No attacks, but I steered well clear of them.
I had a question. Is there a way to tell the drone to save photos without geotags? I don't want that in my photos I take on my phone, there is no way I want it in my drone shots.
Thanks, it's nice to be here!
Welcome to the forum from the beautiful woods of Maine!
I can’t answer your question but there’s many knowledgeable members of this forum willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! There’s a lot of good videos on YouTube that are helpful to the beginner. Fly safe and stay safe!
I ai\m not an owner of this version (Mini 3 Pro) but I would suggest you methodically walk through each and every menu listing to see if you can accomplish an option-out of recording geo tags.
Dale
Miami
Reactions: LoudThunder
There is no way to turn off the geo data within the drone or app. However, you can remove it manually by opening Windows Explorer (PC) select all images (Crt-A) right click and select "properties" then details. Click on "Remove Propeties and Personal Information"
Select ALL and then ok
First off, Crows can and will attack or at least bother a drone… Not always, but you do not want to test your drone's ability to withstand an onslaught… I have 5 neighborhood crows and we are on friendly terms. I actually feed them. This morning, I gave them an egg. They often bring "gifts" soda can tabs, screws, bits and pieces of sticks etc… one time thy brought a toy child's "diamond" ring… We are hoping for someday, the real thing…
But I digress, if you see the birds (crows, seagulls, even mocking birds…) taking an undue interest in your drone, give that baby full up, make it climb…. Birds can swoop, dive, and wing by your drone, but having to climb to attack is not how they do that and they will quickly loose interest. If not climb, get away from the birds, and then land… If you do not the birds just might bring your drone down and not nicely…
Oh, all of this goes for birds of prey, eagles, hawks, falcons, etc… I have never been bother by a vulture and if you do not bother or harass them, you can fly with them…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Montana, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Editing or removing geotagging data depends on what you saved the shot as: a straight JPG or JPG+DNG.
With JPG's - as already mentioned, right mouse click over the thumbnail, click on properties and physically delete any and all editable fields, which should include northing and westing positioning numerics, click on 'apply' and 'okay' to bake it in.
With DNG's - a good RAW editor (Lightroom/DarkTable/RawTherapee etc.) will have a metadata editor built in. Use that to remove any data you wish from the latent image file (DNG) before you process it and export to another file format such as JPG.
Thanks for all the welcomes, thank you GFields for the info on removing the GPS info.
LoudThunder I did do all the minimum legal requirements, have my TRUST cert and downloaded (and read) the rules from FPV Freedom Coalition.
We have everything except vultures here- osprey, bald eagles, golden eagles red-tail and sharpshins etc. Not too many crows at our country place but ravens are close. Will remember the max climb evasion method.
We live on 7 acres on the Bitterroot river, flying along it will be on my to do list soon.
Welcome to the forum. We look forward to your participation and your view of the world.
Reactions: MA2 317
artyboy
