New older user
Glad to be part of this place!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Fly On and Fly Safe…
I love learning and besides photography, flying a drone has become a very rewarding experience. Glad to be part of this place!
At 72 with all sorts of fun issues I can no longer hike and get around like I used to so drone photography and videography has become a real passion of mine. I hope you'll share some of your work although I have to admit there is so much posted here and elsewhere that most posts don't get all that many views, which is OK. Since I don't "work" at getting youtube view and such I have accepted that my videos are just for my own pleasure and for my family and a few 'subscribers'. Here's my (mostly) drone work (and some nonsense stuff). https://www.youtube.com/@digibud/videos.
paul44509
