New pilot from Leduc, Alberta
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Just a quick note from a new drone pilot
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
As a Newbie, here is some Good Old Fashion Advice… Also, tell us what you are flying and we might be able to hook you up with some great links…
Happy, Safe and Legal Droning…
Welcome to the forum! :)
sistersister300
