New Pilot from Melbourne
Martyr_67
Melbourne, Australia
Hey all. New pilot here
I have the DJI Mini 3 (not the pro) for about 4 weeks now
I know it isn't a Mavic. I am here to learn and will ultimately supplement my kit with a Mavic 3 or similar
Working my way through regulations, where to fly etc and improve my flying skills
My main motivation is photography since I have been a still photographer for 40 years+
regards
Marty
DJI Mini 3
Welcome aboard Marty,
This is certainly the right forum for the Mini 3, lumped in with Mavic labelled drones.
Starting with the Mini 2, the Mavic name was dropped from most of the new models such as the Mini SE and the Air 2S.
The continuation here on MavicPilots made sense as these models were already present under original Mavic labelling.
You probably won't find a noticeable difference in the 12mp on the Mini 3 and the 48mp on the M3P (part time quad sensor), it'll still take great photos.
Enjoy the forum, the drone learning curve, and the new aspects of photography this is no doubt providing you.
regards
Marty
DJI Mini 3
I still think it's a Mavic... even. though they dropped the name Mavic off of some of their new drones... air2s mini 3 pro...etc... it's still a Mavic. You are at the right forum.
Since you live Down Under, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3, including the User Manual.
Fly On and Fly Safe…
regards
Marty
DJI Mini 3
Welcome! I'm new here as well and still learning a lot from the experienced folk here onsite. I'm also a long time photographer and wanted to expand my photo capabilities. After seeing drone videos and checking on the specs, I was pleasantly surprised at all the built in safety features, the range and the flight times - and now, the fantastic smooth 4K video and still shots.
Your drone should provide plenty of new challenges and views no new lens can get - looking forward to seeing some of your "sights" from your part of the world.
Greetings, Marty, and welcome to our forum from the friendly skies of North Texas!
We are happy to have you with us. We have over 150,000 members worldwide (including many of your fellow Aussies) who enjoy helping each other learn and grow as pilots and photographers. Anytime you have a question, just ask!
Rich R (alias Hauptmann)
Welcome to the forum! :)
hesitantextraneous
