New Pilot from New York
Dougget
Rochester, NY USA
Hi all,
I just bought a Mini 3 Pro. Having an issue with the remote connecting with WiFi, so my plans to fly have been halted while I get support from DJI.
Kinda frustrating, but hope to get resolved soon and get it in the air.
Bought it for person use to fly around my property. Probably more drone than I need, but wanted to get something that I could grow into a bit.
Glad I found this forum. Planning to learn a lot.
Thanks,
Doug
Welcome to the Forum From Bakersfield!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Thank you for the video. Unfortunately I can't get to any of those screens. During the initial power on of the remote it walks through a few steps where you select language, country, timezone, and wifi network. I can't connect to wifi at that step. I called support and we connected the remote to my PC and did a firmware update on the remote. It is current but still cannot connect to wifi.
Reactions: LoudThunder
From CA to NY - Thanks for joining us @ MP! Lots of knowledge here so you came to the right place! Be sure to scroll down the main forum list to find the forum group for your drone.
Hi all,
Thanks,
Doug
Hey Doug, Welcome to the Forum
Welcome from Vero Beach, Florida.
@Dougget,
Got it,
I read it as you bought it from.
I'm new here. :rolleyes: 👌:)
Rod ..
RobertCNewman
