New to bromsgrove
joshey
Bromsgrove
Hi I’m a new pilot have my operator and flyer id but looking for places to fly in bromsgrove as new to area I tried to look for information about flying on the lickey hills and on the hanbury circular walking trail but can’t find a definitive answer emailed council to ask been 3 weeks and no reply so any help would be appreciated many thanks
Welcome to the forum! :)
Maybe try following up with the council? Or try calling if that's an option.
Since you live in the UK (I think….), there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Bud406
