New to the community
P@trick
The Netherlands
Hi all,
New to this community. Patrick from the west coast of the Netherlands, and since acouple of weeks the owner of the Mini 2 fly more combo. A lot to learn, so find the users with experience for tips and tricks. Thank you for all the information, i’ve got a lot of reading to do.
Patrick
Hello from the Crossroads of America P@trick.
Nice to meet you Patrick. 🤝
Welcome to the Forum. 😎
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hi all,
Patrick
Welcome!! You’re at the right forum. Check the library as it’s a wealth of knowledge and experience from some top operators.
Greetings from Birmingham Alabama USA, welcome to the forum!
Since you live in the Netherlands, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
giraffe
