I'm in southwest Tennesse and am ignorant of drones, but interested in the
Air 2S
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
As an Unmanned Aircraft Systems (UAS) Pilot, the FAA term for a Drone Pilot, there are a couple of Legal Things you need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . The
A2S weighs more than 250-grams (0.55 pounds) so you will be required to register your Drone.
Link to the Pilot Institute Web Site (FREE…)
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
faadronezone.faa.gov
Since you live in Tennessee, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Here is some Good Old Fashion Advice for Newbes…
On the off chance you do get the
Air 2S, below is the link to all of the downloads offered by DJI for the
Mavic Air 2s, including the User Manual.
Learn and download
Mavic Air 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy, Safe and Legal Droning…
