New to this site from New York
inkbombtat2
Schenevus, NY, USA
I have a mavic air 1 and a mavic mini 2 and never got to fly either. The mini 2 had a board issue relating to power(main board) and my mavic air is my baby and I've been struggling on the battery issue. I've got 3 batteries and none of them work. No lights no charge nothing. I was able to get a bypass working but I still couldn't take off and right now I don't have a working pc and I can't figure out how to get rid of battery error with bypass long enough to have the firmware download.
Nice to be a part of the site though.
Hey Ink,
I sent you a private message earlier…
Any case, Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
As a side note, I grew up in Adirondack Mountains, Potterville, on the Schroon River, Warren County, and later in Guilderland, west of Albany…
Back on Point… As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2 and the Mavic Air, including the User Manuals.
After you read the Manuals, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy Droning…
I see that you have already posted your questions about your batteries in other areas and I hope you get an answer that does not include, "Your batteries are dead, they were allowed to discharge too far and now the smart battery firmware will not let them recharge..."
As for the dead PC too. I hope you are not trying to navigate this site on just a smart phone, you will miss so much detail. If you can't fix the PC and you are not ready to buy a new one yet, check out the local thrift shops....
Reactions: Gagey52
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Howdy from the Houston TX area. I think Lykus had a great idea. Sell off what you can and take the money and get something else. I still fly M1P's and from what i understand you get one for $400-$500. Thye may not be the latest and greatest but they are reliable, easy to fly, easy to modify the software (No Limit Drones). and just good overall.
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum. I'm in Schenectady as well. :) Once you get your battery issues straightened out we should get together and fly. Of course, flying here is a PITA with two airports covering most of Albany and Schenectady. LOL.
oldflyer
