Hey Everyone. Looking forward to learn and hopefully contribute to the forum. I'm primarily interested in Search and Rescue and wildlife survey capabilities using the M3T
Greetings from Sudbury, and the West Arm of Nipissing (come summer). Enjoy the forum, and happy flying.Hey Everyone. Looking forward to learn and hopefully contribute to the forum. I'm primarily interested in Search and Rescue and wildlife survey capabilities using the M3T
Wow! Thanks for the advice. I have been watching a lot of how to videos. I have my Basic Drone Pilot certificate from Transport Canada for now. I may upgrade in the future. I plan on flying recreationally at first and would like to try some pet rescue in my area. Someone is always missing a Dog around here, and I'd like to help. I normally don't half-*** anything I do...so I figure the M3T is a pretty good unit for what I want to do.Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Member Map
mavicpilots.com
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Wow, you are certainly jumping with both feet, New to the Hobby/Sport/business and with an almost $6,000 drone… I do not know about your area, but to be involved with S&R in the USA, most organizations require a Part 107 Certification and experience that is not something you can buy… Good Luck with that!!!
But, in the mean time, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
