Newbie from Texas here
newbie from San Antonio Texas area here. Have a Mavic 2 Pro and just learning.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Fly On and Fly Safe…
Hey all, newbie from San Antonio Texas area here. Have a Mavic 2 Pro and just learning. Glad to have found this place.
Hi there, I as well am a somewhat newbie myself also have a mav 2 pro lov3 it so far getting started in the video camera stuff now. In Tulsa, Oklahoma. If any questions ,might be help. Just holler
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! There’s many good videos on YouTube that cover almost every question you may have. Fly safe and stay safe!
Welcome to the forum! :)
Wesleydjimavic2pro
