Newbie here
Hello from the Crossroads of America bjdrone.
I'm sure the mini 4 will be better then the original mini 1.
I am a roofer and hope to use the drone for roof surveys etc and social use also.
Hate to be a spoiler, but you should have the Part 107 certificate for your business and the mini 4 should be registered with the FAA if using it to "Furtherance the business" if flying in the USA.
Also, you need to take the TRUST test and keep a copy with you when you fly.
It's a easy no fail test that covers the basics of flying a drone.
Good luck, have fun, and Welcome to the Forum. :cool:
Hi...i am in the UK and have a flying permit from my last and current drone which i still own.
Double hate to spoil your fun, but the TRUST Certificate only allows you to fly your drone for pleasure, not in your business. Like if you are at the beach and want photos/videos of your kids playing…
The Part 107 Certification and drone registration is required if you use the drone in your business and the Part 107 will also allow you to fly for fun too…
You list your location as "Northwest" so we do not know what you are northwest of so all of this relates to a US location…
Nice to be part of the group and look forward to chatting with you chaps.
I have already written but there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Northwest (if it is in the USA…) , there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the Forum From Bakersfield!
I hate to rain on your parade but since he's a Brit living in the UK, he does not need a part 107 or any of the other things you suggested. He also stated that he had flown drones before, so we might assume he knows the rules already. He would, however, need the British equivalent, should he use his new drone commercially. Oh, and welcome BJDRONE. or welcome back, maybe.
Medium Jock
