Newbie Question On VLOS (UK)
as400
Arundel
Hi all Newbie here from UK.
I am reading you must never loose sight of your drone when flying which sounds fair enough.
My eyesight isn't brilliant with my advancing age, I can see a drome maybe up to 100 ft away, but I am seeing drones being advertised with a 3KM range!...how on earth do you see it when its that far away?
With ones mobile phone would you be seeing what the drone sees sort of thing?...are they in contact?...not sure how it works TBH!
Thanks!
You don't, and can't, even with 20-20 vision ! The 3km possible range should be a big comfort to you in that it is a huge safety margin in terms of signal loss, but in this country at least (UK), and most others, you can't legally use anything like that range, not even with a spotter, who also can't see much meaningfully beyond what you can, standing near to you as the law states they must be.
It's worse than that in that not only do we have to be able to see it, but also judge its orientation, which is orders of magnitude harder if you don't have nav lights or are operating a smaller drone that may or may not have them, or have them on whilst recording ! Also remember that often the landscape, or obstacles in it will usually dictate much smaller limits, and that is usually not much further than you could see anyway. There's no faster way to lose signal completely in one surprising hit than by dropping down behind a tree bank, and that can happen as close as 50 ft to you !
With a Mini 4 Pro, I have repeatedly established that I can tell both position and orientation up to 400 ft (my eyes are also failing with age, but close up rather than far away), which I find to be practically just about enough for most video missions I am undertaking. With my older, bigger Typhoon H it was more like double that. 100 ft wouldn't be enough though, so that may be an issue for you. In that case I would try and extend that range as much as possible by attaching some brightly coloured reflective tape. I've done that with mine, and it does a help a bit, especially beneath 'sky-background' level where the drone is against greenery and foliage. If you use multi colored tape on different sides you can help tell orientation further out too.
Most of the time you will not have a problem flying beyond that if you can see the screen and locate the craft that way (either via the map, the camera view or the radar screen), but I am afraid to say you can't do it legally. But it's also something that is not likely to be called out legally unless you crash and authorities get involved with your flight logs. Even then they are not likely to be as concerned by someone flying 400 ft out than they would be if they are 2km away, and clearly out of ANYONES sight.
So ultimately, your practical maximums involve some level of discretion, and depend on what you are comfortable with in any particular situation.
In the same way that it is widely acknowledged (but rarely emphasised or admitted to) that we all look down at our controllers, and for safety reasons OBVIOUSLY SHOULD DO SO quite a lot of the time, if we were strictly adhering to the VLOS rules, one interpretation of that is that we can't ever take our eyes off the craft, which is clearly madness, from which we could deduce that the rule isn't fit for purpose, and should treated with some degree of leeway (note I didn't say contempt !) for that reason, if not for discretionary ones like the difference between your safe view of the craft and a reasonable persons' and people flying recklessly way out of VLOS range.
Hello from the Crossroads of America as400.
Much like an automobile that is capable of exceeding the posted speed limits, it's up to the individual to obey the regulations.
I rarely fly BVLOS, but it's nice to know that I still have the extra transmission power and control of the aircraft to bring it back in range of VLOS.
A Visual Observer will help in noting the aircraft location when flying to assist the PIC during a flight.
I use strobe lights day or night and they help with me or my VO to locate the aircraft quickly when flying.
Welcome to the Forum. :cool:
Unfortunately you can only see what's out front of your drone with the mobile phone. If you cannot see on the side and out the back of your drone, you cannot see enough around you in order to operate the drone safely. At least, that's the thinking. Just wait a few more years, that will change.
Well on things like the M4P it has already changed, and we can switch to OBS AVOID cams to see exactly that at any time (we have video signal). How many times people practically do that, beyond establishing that it works once is another matter entirely, as is whether doing that would be the slightest bit of help in avoiding fast moving aircraft, which will invariably be a greyscale dot on the horizon, barely distinguishable from noise in those views, until it is waaay too late to do anything about ! ;) So perhaps we shouldn't petition for the revision of that law just yet, at least on those grounds...
I would be happy with it if it acknowledged and clarified that the rule doesn't preclude looking down at the controller for extended periods of time. We should look up at the craft often, but not be required to keep our eyes glued to it and it should not be possible to interpret it as such.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
First off, you cannot legally fly your drone beyond your visual line of sight and that "Line of Sight" is pilot dependent, and it must be done with the unaided eye, you can wear your prescription glasses, but that precluded using binoculars, or other methods to enhance your vision.
If your eyesight was 20/20, you could fly your drone much further out, but as you say, your eyesight isn't brilliant with your advancing age. If you can only see your drone out to 100-feet, then that is the limit of your legal flights (PERIOD).
Think about the transmission/control range on your drone like the speed capability of your vehicle. The top legal speed limit in the UK is what, 110 KPH, but I bet your vehicle can go much faster. You can drive faster, but it is not legal, Right?
If you have a high-end stereo, I bet you can turn up the volume so loud that you are violating the local ordinances in your neighborhood, so you can listen to it so loud that it would cause permanent hearing damage, but it is not legal, Right?
So, just because you can use the video feed from your drone to fly your drone out further than you can see it, do not do it… as has been started over and over again, you cannot see what else is around you and the video feed on your phone is not good enough to see wires, low flying aircraft, etc…
Here is a couple of suggestions to help you, install some navigations lights on your drone.
Maybe install some reflective tape of a bright color "skin"
With all that being said, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
True, if the rule was based on actually being able to see and avoid other nearby aircraft. But since the rule is largely based on making sure to keep control over how far away drones can be flown and nobody wants a drone to be somewhere and the operator is nowhere to be seen...."let's come up with a rule and maybe use the same rule from rc aircrafts where it made sense and call it about safety that loosely claims you need to be able to see approaching aircraft in the distance" as if that has ever happened.
You can have all the sensitive 360 degree special obstacle avoidance cameras all you want, the only way to change the rule is to overcome the "stealth drone" mentality. Or, we can wait for Amazon, UPS, and Google to defacto do it for us. Either way it doesn't matter, most recreational drones flyer don't obey it because it's not practical, it isn't enforced, and as you said, it makes no sense when you need to look elsewhere (your controller) from time to time.
Welcome to the forum @as400! :)
Thanks!
The best way to look at the "3km range" advertised by DJI is to see it as a measure of transmitter signal strength, not possible flight distance.
If a signal can be strong enough to establish a radio control connection at that distance: it should be overpoweringly strong up to 400 feet away... which is a really good thing because that's precisely what you want - a strong, reliable control connection between the drone and the transmitter.
As AeroJ mentions, this won't help if there's a whopping great obstacle blocking line of sight between the drone and the transmitter, so you'll learn to avoid doing this more than once pretty quickly.
When this does happen... and it will (all of us will bear witness to this) the trick is 'corporal Jones'... DONT PANIC! Just take your thumbs off the sticks. Three seconds after the drone loses contact: RTH (Return To Home) automatically kicks in and your pride & joy flies straight back to you on autopilot.
If you cannot see the drone, then you might not see what you are about to fly into or what is about to fly into your drone. This is somthing I have now suffered from which I can only put down to a bird strike.
Thirty metres up over open fields near a river and suddenly the flight goes crazy and I try to avoid the river but the drone lands in flood water. The drone is a gonner.
It appears that the front blade cut through the LED and Aerial leg with catastrophic effect. How did that happen?
Its still a mistery never to be solved.
If you fly BVLOS you have to accept the consequences of your actions including any damage to inocent parties.
Reactions: LoudThunder
From California, US - @as400 - Thanks for joining us @ MP!
LOTS if good info above - the strobe attached it probably the best to maintain VLOS, you can also try colored tape on the arms and/or body to make it more visible. Some have said using that iridescent tape is good too since it reflects light back.
sscott062
