Newbie with a question on RTL and obstacle sensing
anindyanuri
India
Hello my seniors,
I am a newbie, got my Air 3 delivered just before 24 hours back. Not gone for a fly till now. Planning for my first ever flight on tomorrow. My question is,
1. I have set my obstacle sensing set to Brake
2. When I push to RTL and during returning to the Home it finds an obstacle, what will happen? Will it Brake there until the battery exhausted or it will actually return to launch?
What should be the safe settings with Obstacle sensing Brake or Bypass?
My best regards to you all for my first post in this forum. Best wishes from India.
- anindyanuri
Yes.
I always set mine to by-pass unless the job I'm doing warrants me to change the setting.
Welcome to the Forum!
Do you mean RTH?
There is a lot of these new models and terms, I'm really afraid to respond of what I think.
For real, RTH you think is fail safe, but it can fail you, if don't understand what it does.
I have had a couple. :rolleyes:
There is many variables, between models.
I call your question a loaded question. :)
Hopefully you get help on what really need to know at this moment.
For a new bird flyer.
A good day can god bad, really fast.
I see now you are already getting good help!
Rod ..
Hello from the Crossroads of America anindyanuri.
I have a MA2 and have mine set to BRAKE.
I fly VLOS and I can see if my aircraft is about to fly into something.
I make sure the RTH is set higher than anything around me so a collision with something is pretty much non existent.
Your results may vary.
Welcome to the Forum. :cool:
Welcome to the forum, I suggest you read and re-read the RTH section of the manual multiple times.
It seems like RTH behaviour is getting more and more complicated with each new model and it needs to be thoroughly understood and, I would suggest, 'practised' BEFORE it is encountered in a 'rea'l flight.
@Yorkshire_Pud.
Yes for sure, for me reading any manuals my mind drifts to other stuff also It appears they have been translated.
My wife reads A-LOT!
But she does not understand all terms like agl, etc.
Anyways, I will be in the back ground until the OP gets involved.
@anindyanuri
Rod ..
Do you mean RTH?
Rod ..
Are you Rod Machado in Drone Landing Pad instead of the runway? Are you the person I am familiar from my school days? If you are the same, salute you Sir else another salute to you Sir for your kind post and make me bring back to my early school days. Thank you very much for your kind participation to my question.....
Regards
Yes Sir but the problem for a newbie is that, I shall do it correct for 99 times but when that 1 time I shall fail, I am going to out of this community. That is why asking for your experienced solution to tackle the situation in that critical situation so that I shall be safe for my first flight.
Yes, DJI don't provide a printed manual. I come to know that from your post that a manual exists in this real world. Many many thanks, Sir.
Understand your vies. For VLOS I need to react in some way and in case of BVLOS I need to react another way. Great help Sir. Salute.
@anindyanuri
Check this out
@msinger web sight
No not the guy you think, for real me in the military wasn't going to happen. My best bud that help me out today like 2 hours ago. I dropped him off at the Portland Air-Port 1980, when was going Basic training in the Army.
Sorry, I will stay in the background its not my thread!
Rod ..
Since you live in India, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
That's a great help for me. Some of your points I have noted and printed on a piece of paper. That will sure help me forever during pre flight check. Best wishes.
mini3user
