Newbie
jag22
Virginia
Just got my Mavic Pro , I'm a newbie. I have made a few flights and lucky haven't had any issues till today was trying a video and it came out all chopped and full of lines that rapidly come in and out. I don't know if I need to return this or is there a fix, sorry if I posted this in the wrong area I can repost.
Welcome to the forum! :)
Can you upload a sample video to YouTube so we can see what you're describing?
First off, you did post this in the wrong place, it's not a bad thing other than you are less likely to get help as the Pilot Check In Sub Forum is intended for new member to introduce themselves and tell us a bit about themselves…
The best place to post issues that come up with a particular drone is in some of the other Sub-Forums like: General Discussions, Photos and Videos, or your specific drone's Sub-Forum, the Mavic Pro Sub-Forum. These Forums are more closely monitored by the most knowledgeable members with your video issues.
Any case, as a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Virginia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum.
Greeting JAG22, welcome to the Forum from the outback of Australia. I can't help you with your issue but the moderators provide good pointers on the search process. I'm sure that you will find answers to your problem.
Regards
ervinpl71
