Newbie
Welcome to the forum! :)
'm very new to drones (Mavic Mini Pro 4), and look forward to engaging with you all. Will be learning as much as I can in the months ahead, with planned use in West Africa in April!
With your planned trip to Africa, you might want to search postings by @Dale D, he has traveled there recently and posted some outstanding photos… below is one of his postings…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine!
You have time to practice, practice and practice! Find a clear open field and take your time to slowly learn all about maneuvering your drone. There are a lot of good videos on YouTube that will help you learn much quicker than reading the manual. Fly safe and stay safe!
I'm very new to drones (Mavic Mini Pro 4), and look forward to engaging with you all. Will be learning as much as I can in the months ahead, with planned use in West Africa in April!
Welcome to the forum from the Colorado Rocky Mountains. Happy and safe flying!
joelpm
