Newer ND/CP filtered...don't understand what they are instructing
You turn on your drone like you're about to take off and observe the readings. Hold on....
The key is that you want your shutter speed to be double your frame rate. I film in 4k 24fps so I want my shutter speed to be 50, if you film in 4k 30fps, 2k 30fps or 1080p 96fps it'll be different. You want the iso to be 100 and the EV to be 0. BTW ignore any talk of apature(sp?) Since the Mavic is fixed 2.2 I believe. If you could change the apature, you wouldn't need ND filters.
Sometimes Chinese does translate correctly into English: Possible translation correction below
1. These filters can be mounted ONLY WHEN the original stock filter is still in place... ONLY WHEN the original lens is still in place
Please let the filter cover the gold thread on the lens when installing ... On Mavic camera, there is a gold band around the lens. Gold thread=Gold band
dvkhamtruocsinh
