Nice to meet you everyone! Advice?
Welcome to the forum! :)
Either of those drones could be used for recreational purposes. Compare the major specs here and figure out which would best meet your needs and budget.
Hi everyone,
Joining now your amazing community!
I live in the UK and given the regulations I’m very undecided whether to buy a mini 3 pro or a Mavic Classic…
It would be just for recreational use and I’d use it when travelling for holidays (EU / US).
Any advices?
Thank you!
Much less hassle travelling with a Mini 3 Pro because it is under 250g.
@SeaSaltSky right now here in the UK with the current regs, then the only real choice for purely recreational flying ,and the least number of airspace restrictions, is either of the Mini 3 drones but for the extra cost the Mini 3 pro plus the fly more kit,and the RC with built in screen is the only way to go ,for maximum ability across the board
Thank you @old man mavic ! Given majority of my usage would be when travelling to the EU / Rest of world where hopefully the c1 could still fly under a1 regulations, would you still recommend the mini 3 pro or would you actually lean more towards the 3 Classic? I can’t get over how more solid, better built and better specc’d that looks like but again I’m a total novice so maybe it would be an overkill for me and actually more of a nuisance when travelling because of the more stringent regulations extra EU..
totally confused here
@SeaSaltSky ,there are many other countries ,where a under 250g drone is going to be an advantage over a heavier drone
plus of course the weight and size of the Mavic 3 compared to the Mini 3 pro and the overall cost involved
yes it is a substantially more able flyer simply because of its specs ,and can handle a lot more windy conditions than the Mini 3 pro
at the end of the day only you know the exact requirements, that you need from the drone you choose ,do your research, and then make an informed choice ,based on the knowledge you have gained
joining this forum was a good start to your drone adventures ,good luck
Hi everyone,
Any advices?
Thank you!
Welcome to the forum.
You asked for advice and you will get it… But when it comes to making the final decision, it's all on you and you will have to live with the consequences. Not that's it's bad, either choice is good, the cost may be a factor, and the rules and laws, another… The Mini 3 is under 250 grams and the rules are different for you than with the Mavic Classic which weighs more than 250 grams. Besides all the great advice you will receive here, look at lots of YouTube Videos and decide it the differences between the two justifies the cost and possible restrictions in flying either…
Besides all the reading from the responses you will receive and this (admittedly long reply, I have attached the link to all the downloads for both models, including the User manuals…
Since you live in UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below are the links to all of the downloads offered by DJI for the Mini 3 Pro and the Mavic Classis, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
ethanp12
