NO back left leg slips out during flight
BanksAJ
So after a couple of crashes, the back left leg on my mavic pro slips out of its housing by about 3 to 4 mm during flight.
Does any one have any links to how to videos or articles on how to sort this problem out. I'm in Zimbabwe Africa and there are no real options to order parts or send to a repair shop or DJI care.
Much appreciated
Al
Can you post a picture of it in its fully loose position? That is one thing I dont mess with, structural integrity. It can affect your thrust line and make the drone fly erratically, not to mention it could possibly just come completely out and dangle by the wires. That wouldnt be pretty.
As @Simmo said, if you insist on flying, glue it on tape it on, or rubber band it on. It wont be safe, but at least you'll get your shots.
OMG!!! I thought you meant LEG, like a leg you stand on......
A Mavic has Antennas in its front LEGS, but its back LEGS, are nothing more than plastic stands.....
This is what I thought you were on about!
Your photo shows the complete rear ARM, which has props attached!!!
No, dont use my advice and glue it back on!!!!
It needs to be fixed properly!
So ended up gluing with rubber epoxy glue and it seems to be holding well and folding correctly. Feels good. Sensors swapped out. Camera swapped out. Front leg sorted. Just left to calibrate everything before I fly. Any pointers on how to calibrate my mavic pro?
erintse
