No critical battery warning slider in dji go 4 app
Mic Mac
Just set up new mavic 2 pro and did all updates. However i cant seem to find the critical battery warning slider typically set at 10%.
I only have the low battery slider typically set at 30%. Any ideas why it may not exist as i have followed all directions and watched all video links on startup guides on utube and cant oick what i have done..
I am using samsung note 8 as the connected device..
As you can see on videos etc the critical level is no longer configurable on the M2.
Should i still be able to see the setting greyed out as it does not exist for me at all above the low battery warning slider where im used to seeing it?
You can access it with Assistant in debug mode. Non DJI battery and battery type 3 can still be set in Assistant as well.
Stephen King
