Northeast Saskatchewan checking in!
ragtopjrz
Nipawin, Sk, Canada
Hello I am from a small community in NE Saskatchewan with my second used drone with limited success.
My first was a used Phantom 3 Pro which due to the motor and fuselage parting ways it parked itself in a tree!
I bought a used Mavic 2 Pro last year with hopes that I could do some mapping of our acreage, and possibly even some gravel pits at my work to learn on....
I have taken some cool video of our property which I am happy with, and hope to get better with the drone flying skills, however I still have yet to figure out a solution to be able to map that does not require me getting a second job to pay for the software!
I also seem to run into roadblocks every time I try and do something. This weekend I was trying to calibrate the vision sensors, so I downloaded DJI assistant 2 (consumer) and attached to the drone, did all the updates it would allow, and then went through the calibration process, and then got to the calibration part where it did not move off 0%. I tried reinstalling and tried it again with the same results!
I look forward to leaning more about what I can do with this drone from all of you here!
Thanks
Ed
I am from a small community in NE Saskatchewan..
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
From your note, I do not expect you to be very experienced and thus the advice below… I cannot help you with calibration issue, but others have offered advice…
You mentioned "small Community" so I googled your town, and that old, steel girder, one-way at-a-time, bridge (Old Highway 35 over the Saskatchewan River) looks like fun, especially when there is a train going overhead at the same time… WoW!!!
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic 2, including the User Manual.
Fly On and Fly Safe…
fecteo
