Not quite sure where I went wrong
fowleronline
Hi, I've had my Mavic Air for a couple of months now and had my first crash yesterday. I've flown it quite a bit, but I am no expert and I'm now doing my "Air Crash Investigator" thing... black box was recovered!
Problem? crashed into the sea
Was unit in a crash? more of a plop...
What have you tried so far? still drying it out, not tried it yet.
What device are you using ( iphone , ipad, Samsung , etc)? Samsung s7
What firmware are you running ( aircraft, remote controller)? Latest version
What Go app version are you using? v4 - latest
Any modification?
(if so what) no
Did you change anything or install any apps? (if so what) no
Do you have a video or pictures of the problem? (if so post link) no
If I have done this right, the log is here... DJI Flight Log Viewer - PhantomHelp.com
if not it should be attached to this thread.
OTHER INFO.
The flight was in the UK on a beach where I have flown many times. Take off was literally 1ft above sea level. It's very gently sloping beach. I had taken a couple of pictures back towards the beach where my family was, and decided I wanted to be in closer.
I hope this works...
I was about 10' above the surface and wanted to be about 5'. There was a 5mph steady wind and it was not a problem. Bright sunlight at about 10am, tide coming in, virtually no swell. Total flight 33 seconds. Wend down in knee deep water so about 18" off the sand.
The text log I uploaded and the log in the DJI4 app show different heights. The app shows stick instructions, but I can't see them on the log, is there something else I need to look at/upload?
Thanks in advance for your advice.
You can see the stick positions (columns AG - AK) in the CSV file that's attached to the log you linked above. Your log shows you held the throttle in the full down position until your Mavic crashed into the surface of the water.
Thanks, I remember "blipping" the down to drop those few feet as I flew in but it felt like it just flew into the surface. I cannot see the columns you show on my computer, I only get...
Time Flight Mode GPS IMU
Altitude
VPS
Altitude
Speed Home
Distance
Battery Battery
Voltage
Cell 1 Cell 2 Cell 3 Cell
Deviation
Message
where do I find the others please? I don't remember any proximity warning either, does it show that please? I don't know if there is further telemetry that I cannot see (though I would probably not understand it if I did).
Thanks again.
Altitude
VPS
Altitude
Speed Home
Distance
Battery Battery
Voltage
Deviation
Message
Thanks again.
It looks like it continued to descend after you released the throttle, but only for 0.5 s or so. I think that you were expecting too much to be able to use that level of precision and timing working within a meter or so of the water.
Thanks again, I did not realise the CSV file was different to the log file, I thought it was just a different format.
I'm sure this will have been my fault, but I am trying to understand why, having done this manoeuver many time photographing my dogs., it should have gone wrong this time.
Any thoughts on the collision avoidance warning - I can't see anything? I don't remember an alert, would this be on the log?
On the log, It only looked as if I down throttled for half a second, am I reading it wrong? That close to the ground I usually hear something, it shouldn't plough into the ground. Is it reading the heights correctly, I cannot find that.
Sorry for all the questions, I'm sure I will read these sheets better with practice.
Thanks.
Thanks.
I would not trust the downward sensors over water.
...That close to the ground I usually hear something, it shouldn't plough into the ground. Is it reading the heights correctly, I cannot find that...
The downward sensors can have difficulty detecting water so they cannot be relied on to stop your decent.
Thanks, I was not relying on it, I just don't remember it doing any warning even though it was registering a low height on the log. Anyway... It's had 48 hours drying after a good wash and... it's dead, and obviously the battery too.
Time to find a service centre and see how bad DJI support really is (allegedly).
Well... I will try to learn from my mistakes, one of many I have no doubt.
Thanks again.
Time to find a service centre and see how bad DJI support really is (allegedly)...
There is no low height warning. You can launch from a hilltop and fly down and Go 4 will show your height in negative numbers. If landing precision is turned on it may stop the decent and give you an area unsuitable for landing message, but this may not work over water.
I am sorry for your loss. I had a "mishap" and got my replacement from CA in 10 days.
A CSV file isn't a proprietary DJI file, it's just an industry standard raw data file that can be recognised by, and pasted into, pretty much any spreadsheet application (and a few other things besides). I don't know what data it holds in this case but normally it would be pretty much everything unless there are multiple CSV files for different areas of telemetry.
This actually saved me the first time I flew over the ocean. I pressed the auto landing button instead of return to home and was waiting to see the drone come towards me. Looked down at the screen and bugger me, unsuitable for warning Hahahahaa.
It happens, If you do fly again give the manual a good read,
its said a thousand times I know, always the number one culprit of pilot error it seems.
TPS
