now thats a beast of a set up..
Cpt.Barbossa1072
this beast of a setup was from a guy whom recently posted on FB, consists of the SmartController ,Alientech 5.8ghz signal booster,modded &
mounted onto a Lifthor SC/Pro bracket with a Freewell FW279 7" monitor is a beast of a setup...
Seems to defeat the whole purpose of the SC setup!
With something as non-portable as that you might as well use an Inspire and have a better drone than the M2.
That harness setup would be a little unbalanced where it is.
If hanging from the neck the only way it might work is to have the tripod arms counterbalancing on your waist.
Terribly uncomfortable after a short while.
Even if it's a waist strap, it looks awkward.
I can't imagine this is a Thors product, Sunnylife controller ?
Maybe Thors just saw it and reposted.
Great if you've set up a base station with small table etc to work it from, and of course it's left assembled !
Well I could see all that minus the SC if I still did all the distance trials but with the first MP I quit being it would go over 4 miles plain. That on a table top and battery mods would be ideal . Just sayin if you like...did those things. ?
Reactions: GadgetGuy
I use both straps, the LifThor centre strap round the neck and the sunny life strap round the waist or chest, when tightened up enough it just don't move anywhere and stay perfectly positioned. also use a tripod as above if I want to sit and there is a place to stand it on, but not done that much.
Reminds me of the old P3P and P4 days where we needed external batteries and a full Star Wars setup just to reach the advertised range. What a pain! That all became obsolete when the stock P4P and stock M2 actually delivered on advertised range and battery life! Once you've tasted steak, it's hard to go back to hamburger!
EscRen
