Old fart from Wirral UK
Hippytitimus
upton wirral
I have one of the cheapo drones that I’m quite impressed with but, it’s an L900 pro se max I had a lot of problems setting it up with an iPhone XS Max as it wouldn’t show any video link of camera, I finally sorted it by turning the phone to aircraft mode and all was well and video plays out fine now. But going back to when I first flew it, that was fun, I set it all up with the giro etc. pressed to take off and flew it around a bit, then decided to test out the one button return, for the next few seconds I had to search for where it had gone, ah, there it was straight up at about ???feet and showing no sign of landing, trying to bring it down manually didn’t work either so I struggled to keep it over my garden in the hope it would eventually run out of steam before I did. After 5 mins or so it started to descend and a bit of nifty controlling on my part, (well I thought it was good for my age). It came down and I retrieved it in one piece. Now I have the phone connected I now want to try flying it again so am in need of any help I can get so any suggestions other than give it up would be much appreciated or any local drone flyers that could possibly show me the ropes please
Hello from the Crossroads of America Hippytitimus.
A member here on the forum(s) may be able to help if they have the same aircraft.
Good luck and welcome to the Forum. :cool:
Welcome to the forum :)
Most people are flying DJI drones here, so you probably won't find your L900 pro se max answer here.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
As has been mentioned, this site is really "wrapped around the DJI Drones" and we probably do not have the know how to help, but some members might have this drone and they will help…
However, at the end there are some links and videos for you to check out…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
booboobambos
