One of the best drone pilots
Are you able to fly your drone forward and then used the same route on your map to fly backwards full speed? Is that possible?
Cheers
Daasmangi
You can set waypoints flying forward and then have the drone fly the waypoints while you turn the drone any direction you want. Just turn the drone so it is facing backwards to the direction of travel.
Billy Kyle demonstrates it in this video
That would be the 'less-skilled' way of achieving the same effect.
(I do believe Mattias is flying backward.)
With the Litchi app you can create a 'mission', save it, make any adjustments necessary, add to the flight mission and then re-fly the corrected mission. You can change the route, the height, the point of interest for each way point. You can point the camera in any direction and still have the ability to fly your platform in any direction. You can change the speed at which you are flying. I have been able to choose if I wanted to fly in front of a tree, behind that tree, over or under a particular branch. You can fly the first mission @ 1 MPH if you want to and then speed that up once you know all your way points are safe.
So, the short answer is YES!
0x6e08715
