One of the middle leds of the battery turned off during and after charging
viking-pilot
After I updated successfully to fw 1.04, I was charging the batteries, but one of the middle leds was turned off or bypassed.
Your comments would be appreciated
Faulty led? What happens if you press once the power button? Same? If you plug the battery to MP then what is the status of the charged battery? Can you check please the status that dji go 4 show in battery section?
Reactions: viking-pilot
Maybe due to the battery update
I’ve tried to refresh the fw for updating the battery. The Led turns on after the updating. But when restart the drone it turns off again.
I repeated the updating again. This time the led did not turn on.
Please let know other method for updating the battery.
Thanks
I do not know if it is a faulty led. Al leds blink less one of them. I pressed the power button with same result. What do you mean please MP? I can show the stays of the battery, it seems fine. Thanks
Thanks
I did all my update directly through the App
I believe if you press and hold the button down for greater than 30 seconds it forces a battery reset
The LED has gone to a better resting place. It want to scare your drone to thing there is no power at 60% so it can fall from the sky..... Just return the battery
To make sure it's just a faulty led, and nothing critical, I'd put that battery in the Mavic and let it hover over something soft in case it falls. If all goes well you should be fine
Reactions: Chris_GREECE
I did it and then I charged it full, but I got the same issue. Thanks.
If you are concerned about the battery and it is under warranty just return it for a replacement one.
luhf
