Oops after overlooking a Litchi mission planning detail
EricF
Quebec, Canada
I'd planned a 6-minute circuit to get video of a friend's cottage nestled in trees near a frozen lake. All looked well, with the elevation of the waypoints over the forested area set to 45m (~150ft), so well above even the tallest pine trees. Just to be sure though, before starting the mission, I put my Mini 2 up to 45m and everyone agreed that it was definitely above all trees.
Waypoint #1 was 10m above the ice about 20m in front of the dock, so I brought it down to get a picture of my friend & his 2 grandchildren before invoking the mission.
Waypoint #2 was 25m up, but as the Mini 2 climbed to reach waypoint #3 at 40m, its path intersected with a pine tree. As a child's voice was calling out "Its gonna hit the tree!" I was frantically trying to abort. Too late: we all saw it hit a branch, then tumble into dense foliage!
The camera was still running, so we could see it was resting on one side with pine needles waving around, but we couldn't see it (even with binoculars). However, I was able to get the sensor details from AirData to determine that it had registered an event at 99ft (30m), then a couple of seconds later, another event at 70ft (21m). The first was probably when the prop struck the branch; the second was likely related to a displayed warning that the angle was too steep to fly.
From directly below, I noticed a squirrel venturing out on a limb far above. I'd switched over to DJI Fly by then to be able to turn on the buzzer, so when I hit it, the squirrel ran back... then tentatively started out again. Another buzz & another run: I still couldn't see it, but now we knew where Mini 2 was 70 feet up.
Luckily I know an arborist & professional tree-climber, who agreed to do a rescue climb the next morning. The kids found the tree climbing much more exciting than the aborted drone flight; my tree-climbing friend can now add "drone rescue" to his list of services; and I know not to ever overlook the ascent path when gaining altitude!
Oh, and Mini 2 after its night aloft? A right rear prop had a tip broken off, but with a new battery, it started normally — and I haven't encountered any problems since replacing the prop pair.
The Litchi mission plan: the red arrow shows how far it got!
Way to tall to climb...
...unless you have the gear and know how to do it safely!
Eric, were you flying IOS Litchi Beta or the new release below?
Also, I read on another forum that you now to have to fly the mission to create waypoints which defeats a lot of it's benefits IF it is true. I wanted to plan a mission on my Macbook Pro and sync with IOS devices.
Can someone shed some light on this?
_______________________________________________
You don't need to fly a mission to make a path of waypoints. It would be cool if you could...
As Dronut stated you do not have to fly a mission, it all can be done in Litchi Hub sitting at your computer at home but there is a option to actually fly the mission first and use this web page to generate waypoints after the flight by using the CSV file from airdata. Kind of a cool option.
Unless something has drastically changed (And I'm not saying it hasn't) you can absolutely fly and create waypoints within Litchi.
Edit: Unless it's a limitation with the Mini line of Mavics which I'm not familiar with. . . .
Reactions: umanbean
Nothing has changed @BigAl07 , planning a mission in your computer using the mission hub with the Mavic line (Mini included) is perfectly doable.
Reactions: BigAl07
MANUAL PLANNING WHILST FLYING
(When using a Mini 2/Mavic Air 2/Air 2S)
In the Litchi App set the function button (KEYS) of the remote controller to ‘Waypoint at Aircraft’.
In Waypoint Mode tap the onscreen Mission Setting button and set:
-Heading Mode to ‘Custom(WD)’
-Finish Action
-Path Mode
-Cruising Speed
-Default Gimbal Pitch Mode to ‘Interpolate’
-Rotation Direction to ‘Managed’
Now fly your drone manually to a point of your interest (not a POI) and aim (frame) the camera.
Press the Function button to create a waypoint.
This waypoint will include the position and direction of the drone AND the camera’s pitch angle (Gimbal Pitch).
Fly to the next location and do the same (up to a maximum of 99 waypoints).
When there is an obstacle between any of 2 waypoints of your interest, you have to include waypoints whilst flying around it.
When you’re done flying, save this created mission and run (fly) it.
You may possibly have to fine tune it either on your phone or in the mission hub.
Like:
In Mission Settings:
-Finish Action
-Path Mode
-Cruising Speed
In Waypoint settings:
-Speed
-Curve Size
Advantages using this method:
-You can actually frame a subject realtime, no guessing of distance and camera angle.
-You are aware of any potential obstacles and deal with them.
-Most likely NO unexpected control signal loss trouble with VSC-drones.
Good to know about being able to save waypoints for a mission during a test flight @Agustine !
To @DroneSolutions question: I'm using the Android version (Pixel 4XL with current version of Litchi), and all of my missions (so far) have been set up using the Litchi mission hub running in a Chrome browser, with the "Chrome Litchi Virtual Mission" extension to allow me to export a mission to Google Earth so it can be "played". (I'm using it on Windows 10 Pro 64-bit.)
Since support for iOS is apparently now available, you should be able to create your mission on your Mac and save it to the Litchi cloud (you need to set up an account for that as part of running Litchi). I highly recommend also setting up an account with AirData so your flight telemetry is synched and available immediately after for analysis.
My tips for making Litchi missions? Start with the "Settings" button to set the overall default settings to apply to the mission (like cruising speed, path mode, "use online elevation", etc.). If you are using points of interest (POIs), set them roughly next (by right-clicking) because by default, waypoints will point to the closest POI. Create waypoints by left-clicking (and click "Delete" in the dialog if you make one accidentally). If you want an intermediate waypoint between two already set up (for example, to add one in the middle to take a photo), click the "Insert" button on the first waypoint's dialog: the new one will be inserted halfway between it & the next one.
Reactions: umanbean
After this experience, I bet you will be hard to crash again.
I hope to share my own tips here, too.
Prior to planning any autonomous flight to a new location, I used to take sphere 360 panorama pictures with different altitudes.
The process is something like this:
Start the drone ==> Climb to 20M ==> take picture ==> Climb to 25M ==> take picture ....
It takes about 5 minutes to 10 minutes to do the inspection. And, after reviewing the inspection pictures, I will understand the location very clearly. Doing this way is pretty easy to make "no-crash-at-all" flight plans.
Reactions: EricF and umanbean
Sorry....been down with a persistent virus...not C19...I appreciate the feedback. Just like different cable television sources you can often get misinformation from forum postings or I am the one who misunderstands what is being said. The weather has been horrible in the Chicago suburbs and have not been able to kick the tires of the new Mini 2 Litchi release. On one of the few nice, flyable days, I have had commitments preventing me from trying it. I usually don't try a new flight app release for any of my drones until it's been out for a few weeks. But will give the new release a try on my 1st decent day. Thank you.
-Finish Action
-Path Mode
-Cruising Speed
Like:
-Finish Action
-Path Mode
-Cruising Speed
-Speed
-Curve Size
When you say (as a beginner to this) - "When there is an obstacle between any of 2 waypoints of your interest, you have to include waypoints whilst flying around it." If you are planning out a flying session on yr PC, and are unsure of elevation when you already have a hint that destination is higher than departure spot....what are the options....cause I've been told by a friend Google Earths .kmls will allow elevation, but does Litchi import these Google Earth things to help with your mission...?
As I understand it, both Litchi and Google Earth access the same topographical database that shows ground height as distance from mean sea level.
Consider flying a Litchi mission at, for example, 30m above the ground level of your starting point. In this mission there is a hill that at its highest is 80m above your starting point. Make sure to (at least) include a waypoint on the top of the hill that is also 30m above ground level.
The reason why I say "at least" is that you cannot be certain that your drone and the hill both rise at the same rate - for example, if the highest point on your hill had an almost vertical cliff in front of it.
We would need to add waypoints earlier in the mission to make sure we get above the obstacle.
nikitindiz
