Opinions on case I am designing....
MavProPlat1968
NE TENNESSEE
I have been playing around on mycasebuilder.com and designing a case with spots for what I would like to carry. The design is for the Nanuk 933. From top left to right...
Mavic pro with storage underneath
Controller
Battery adapter
4 batteries
Charging hub
Home charger with storage underneath and channel cut for cord
iPad Mini 5
Tablet holder(Uzopi 2 piece) with storage underneath"
Reactions: Former Member
Controller
Battery adapter
4 batteries
Charging hub
iPad Mini 5
I love ingenuity!
Well...they cut it if you order the case...you design and order, and they use your file to cut it. May be a little more than I can make myself spend on a case right now though. I think it's like $208. But it does have what I want, which is hard to find on pre-cut cases.
Maybe a space for a car charger, they are always a funny shape and take up unusual space. Make it not a lay flat cutout but an on edge cutout to save space. Or a lay flat with cut out space below it, for the long battery connection cables they always have.
Reactions: MavProPlat1968
Space under mini will fit the smart controller?
I'm not sure of the dimensions of the smart controller, but I'm sure there is room to put a cutout under it that will work. The foam I posted is 4.5" deep so I cut the iPad mini slot .75" deep so you still have 3.5" to work with. That would leave .25" of foam in the bottom. You could send me a smart controller and I could measure it up and let you know for sure. ;)
Plenty of room left. Love the two level design, reminds me of my GPC. CS with sunscreen attached fits in less foam depth.
One thing you might add is two thin cuts at each end of the upper layer so that you have handles for easy removal and access to the lower level.
Address?
4 13/16 top to bottom
6 7/8 side to side at top
7 1/16 side to side at bottom
1 3/4 thick
I leave the car charger in the car. Never enough room in any of these cases.
If you’re looking for one for an SC, I just got this one yesterday.
I have so many cases now that I will probably need to get a bigger truck to cart them around. I’m liking the one the op is doing with the thought of the sc under the mini. I’ll do a little research as I’m kinda partial to the tomcase and the mccases brand. Maybe I could send one to them and have them custom cut the foam. The nanuk is a good case, but I really like the latches on the ones I use. Just what I need, another project!
Those dimensions will be on the tight side which is what you would want the foam to be. The other consideration would be something on the bottom like the screws or bracket that a lot of people are using. So maybe I’ll include that idea.B88E487B-12AD-4DDF-8DAD-6EDCF37EF60E.png
DonOh1
