Out of box, no gimble camera
McBiteMe
Atlanta, GA, USA
Did I get a deal one? I fear I may have. Firmware updates and still no camera. Controller will not even list camera serial number.
POOP!!!
If it has no camera, then return to seller for refund.
Reactions: Donnie Frank
Strange first post, but welcome to the forum.
Did you mean to post a 'dead' one ?
It sounds to me like the camera is present, just not recognised by the drone / firmware.
Yes, if new return to seller (store) as it should be exchangeable or refundable not working as it should.
If 2nd hand, you might be in for some more hassle with a seller.
Good luck with a replacement or refund.
After a call, I hooked up to a computer and did the firmware on the drone. Error 30064. I did get a pic on the camera when I took it outside, but now with that error, it will not take off. Called DJI once more and was given the option of a refund or replacement. I would rather not as it is registered already.
Anyone know how to fix 30064? All the latest firmware is installed and refreshed twice.
You have a new item that apparently is defective, why not get a replacement? Just because it is registered you would rather keep a defective item. What's the real issue?
Good you're simply getting another drone, as it should be.
For your (and others) info, there is a current thread about the 30064 error.
I haven't read this thread as it's of no interest to me . . .
…was given the option of a refund or replacement. I would rather not as it is registered already…
If you’ve registered it as a Recreational drone, all you need to do is log back in to dronezone.faa.gov, go to the Recreational Flyer Dashboard | Device Inventory, remove your old serial # and add the new one.
Rec flyers get to use the same FAA registration number on all their Rec drones!
Reactions: Zeke
Mr. Jeff
