Pano
EsiMavic
IOS 11.1.2 dji 4.1.18
I don't have the pano mode
Where can I find it? Or do I have to upgrade to what version?
Pano mode is only available if you're flying a Spark.
Reactions: EsiMavic
Yes, that mode is only available on the Spark for the time being. I'm hoping they will add it to the Mavic and P4P soon, this is the biggest reason I use Litchi right now.
Try using Assistant 2 it should see the update.
Updated and no Pano mode showing up. Late night here, so couldn't try it while flying yet.
I finally got it to go this afternoon... Third times a charm I guess. Pano mode worked fine, the compiled pano in the DJI GO app is pretty nice. I did however have a hard time compiling it later in Kolor Autopano Giga. Not sure why, there were missing portions in the final render.
If you have images with no distinct differences (I.e. blue sky, no clouds) it's hard (or impossible) for the program to stitch the frames together.
Hence the blank spot(s).
Adjust the recognition parameters and try again:
Quality of detection: High
Number of control points: 200 (default 100)
DigitalJoe
